跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Home button not working
so my iPhone 7 had a cracked screen so I bought an ICloud locked 7 with a good screen to fix mine with, both phones home buttons functioned perfectly fine before the repair, I took the home button original to my iPhone and put it into the replacement screen, and the home function nor the Touch ID is working, I have completely taken apart the home button assembly and put it back together, I have even tried both home buttons and they don’t work, I have also carefully inspected the cables but none have any visible damage, I don’t know what else to do so I’m asking this community
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Let’s call your original phone “Phone A” and the for-parts model “Phone B”.
You say you moved Home Button A onto Display B, and Home Button A didn’t work.
If you put Home Button A back on to Display A, does it work on Phone A? If so, then either Display B is bad or Home Button A wasn’t seated properly on Display B. If not, then Home Button A was damaged during your repair attempt. The Touch ID circuitry is RIDICULOUSLY delicate and very easily damaged.
这个答案有帮助吗?
得分 0
2条评论:
The a button doesn’t work on the a screen, I think I might have damaged it
完成的
Unfortunately that would be my conclusion as well.
完成的
添加一条评论
Have you afther you switch the screen and home-button connected the iphone with itunes and restore it? Sometimes this will help.
这个答案有帮助吗?
得分 0
1条评论:
No I haven’t tried that
完成的
添加一条评论
添加你的答案
Vipaha 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 21
总计 302
