跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
PS4 System Install Problem
I took my ps4 to a technician because I had no video output. He changed the integrated video chip, but was unable to reintall system. I am trying to do it myself, but for some reason when asked to insert the pendrive with the system software, i am unable to press the Ok button(controller connected to usb and working). On the other hand, all options in the safe mode are disabled but option 7.
Edit: I am Adding images of the problem.
https://imgur.com/a/muivaSJ
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
use the d pad on the left hand side of the controller if not I have no clue
完成的
Tried both the pad and the L3 button.
完成的
添加一条评论
2个答案
已选择的解决方案
After Trying everything, found out that the problem actually was the “right“ pad button in the controller. Now a new error presented ce-35888-2. I will open a new question for this. Thank You EveryOne!
这个答案有帮助吗?
得分 0
添加一条评论
Did you tried to format the drive before you put it back in the PS4? Otherwise try another (empty) HDD just to test.
这个答案有帮助吗?
得分 0
4条评论:
I didn’t format it. But Tried a brand new sdd, and It was the same.
完成的
Did you download the full software (not update only)? And the USB is FAT32 formatted right? When it should reboot the console, does your PS4 reboots or turns off? If it turns off instead of rebooting, please unplug the power cable and connect it once again, then turn it on.
完成的
I downloaded the full software, and formatted the pendrive to fat32. I never get to the reboot part of the process. Check images for clarification on the error. https://imgur.com/a/muivaSJ
完成的
Ah I get it now. When you try the controller with bluetooth it won't simply connect (keeps searching, flashing white light) ? And with USB it's not working either. And did you tried multiple controllers ? Perhaps it's even related to the USB ports on the motherboard... Did you tried other USB ports, also the backside?
完成的
添加一条评论
添加你的答案
alvarez_fernando_l 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,781
