跳转到主内容
红米note系列是小米主打高性价比的大屏手机系列
60 个问题 查看全部
Battery changed but doesn't charge correctly
Hello everyone,
My redmi note 4 doesn't charge correctly. It stays at 2%. I thought it was the battery so I changed it but it didn't fix the problem. Do you think it comes from the charger port or from the other internals? What do you reckon I should do?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Guillaume Bregeon since you already replaced the battery and it still shows the low charge it could be the connector but it could also be related to a bad PMIC . You will have to check those things out. Ultimately I’d start with a new charging board and re-evaluate after that. This shows how to replace the board. If you have the tools and the knowledge to test, you can use this schematic for reference.
Update (02/09/2020)
Start with replacing the charging board. It may just resolve your issue. If you replace it and it does not resolve the issue, then you will have to consider board level repair. Soldering a small board with some really small components requires some good tools and good skills. You would need to post some good pictures of your boards with your question 在已经存在的问题里加入图片 so that we can try and help with identifying components etc.
这个答案有帮助吗?
得分 1
1条评论:
I'm not exactly sure how to find the right component for the right phone. I have a xiaomi redmi note4 Chinese edition. I'm new to solderingbut I'm tempted to give it a go.
完成的
添加一条评论
添加你的答案
Guillaume Bregeon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 146
