跳转到主内容
The second generation of the Mazda 3, also known as the Mazda3 and Mazda Axela, sedan and hatchback series by Mazda.
10 个问题 查看全部
Sanyo CD player to radio ribbon cable path?
During repair of the single CD player in my 2014 Mazda6, the ribbon cable that connects it to the Radio motherboard detached at radio end. Ribbon cable has less “pins” than “receiving” part on motherboard and don’t know exactly where it should be reattached. Unit was built by Sanyo. Mazda claims it does not have repair manual.
Advice on how to find connection point welcome.
GL McCormick
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What I would do is go to a junkyard and buy a used one. The problem with trying to rewire it is it’s going to be difficult without a manual :-(. Unless you get it right, you’re going to fry it. I kind of do not believe Mazda as these are OEM’d out for them, but maybe it isn’t available to the service department because they just replace assemblies.
Best you can do is look at it and use common sense to figure the easy ones out, and work on the difficult ones. You might be able to find a internal reference online with the radio Part#. Photos may help here if you need an idea of how.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary McCormick 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 160
