跳转到主内容
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Black lines on display screen iMac 21.5in A1418
Hi
I have IMAC 21.5in A1418 Year 2013 with black lines on the screen. Is there any quick fix? If not do I need to replace LCD or can it be fixed? Is it LCD or graphics card?
Please help me in sorting his out.
Thanks
Kaz
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Black lines are bad TAB connections (TAB error). It sounds like someone had difficulty taking the display off when trying to open the system.
Sadly, there is no means to fix this damage. You’ll need to replace the full display assembly 2013 21.5” iMac Display Assembly, Apple P/N 661-7109 (Used) $440 USD. You’ll also need this kit: [关联产品丢失或禁用: IF173-005] and here’s the guide you need to follow to properly remove the display iMac Intel 21.5" EMC 2638 显示屏更换件
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Muhammad Kashif 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 239
