跳转到主内容
Whirlpool side by side, I have water, no ice.
I have changed the valve from the water supply. I have changed the line from that to the fridge. I have changed the inlet valve. Cleared dust from the inside. I get water ..no problem. For some reason it doesnt seem like water is going up to the ice maker. Even cleared the upper tube in the ice maker in case there was a piece of ice jammed up there. I am losing my mind. Its only a few years old. Water doesnt seem to even be going up the tube to the ice maker. Any ideas? Ive even tried putting a small amount of water in the ice maker to see if it'll make cubes. It does.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Please give us your model number
完成的
Model is WRS325FDAB06
I changed inlet valve and my pressure is good.
完成的
How do you clear the tube connecting to the ice maker. I, like you, have changed the valve, filter, and nothing. Still not getting water to the ice maker. I also pour water manual and it made ice. Not sure what to do and I don't want to call anyone out and pay for them to do something simple. Let me know how it turned out for you. Thanks
完成的
添加一条评论
1个答案
已选择的解决方案
Water Inlet Valve
The water inlet valve is an electrically-controlled valve that opens to supply water to the dispenser and ice maker. If the water inlet valve is defective, or if it has insufficient pressure, it won’t allow water to flow through. As a result, the ice maker won’t make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi. If the water pressure is sufficient, use a multimeter to check for power to the water inlet valve. If the water inlet valve has sufficient pressure and is getting power, but the ice maker won’t fill with water to make ice, replace the water inlet valve.
这个答案有帮助吗?
得分 2
1条评论:
When the door is closed, will it dispense water?
完成的
添加一条评论
添加你的答案
TE M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 54
总计 2,435
