跳转到主内容
Leaking at the bottom
I have a side by side Whirlpool and we have the water turned off in the back but yet we still have water that leaks out from the bottom of the freezer side. This has been an on and off thing for a month now. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If the defrost drain is frozen, the water will overflow the drain trough and drip down to the bottom of the compartment. This water can eventually leak onto the floor. Check the defrost drain to determine if it is clogged or frozen. If the defrost drain is frozen, thaw the ice.
这个答案有帮助吗?
得分 1
添加一条评论
The leak could be from defrosting the ice. There is a cycle to defrost the ice and usually the water is evacuated trough a pipe to a small reservoir on the top of the compressor to evaporate (once or twice every 24hrs). You need to check if the water goes to the right place and to make sure the pipe is not blocked (damaged).
What’s the model?
这个答案有帮助吗?
得分 1
1条评论:
I got the same issue...
Model number MF12269VEM10
完成的
添加一条评论
添加你的答案
Scott Hicks 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 116
总计 3,121
