跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
208 个问题 查看全部
Physically moving my Mac pro ssds to my mac 2012 mac mini
So I’m wondering if I install my 2 ssd drives from my 2008 Mac pro and put them in my 2012 mac mini will I have any issues? I’m letting go of my 2008 mac pro because I can not upgrade it any longer. So I’m buying a bunch of external hard drive enclosures and creating my mac mini pro…ish My mac pro has El captain on it I will be able to go to majove on the mac mini… But my 2nd ssd has my virtual instruments on it. I’m not trying to create a fusion drive of any sort. I’m just transfering my existing drives to my new computer will I have any problems installing the 2nd ssd drive?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I can tell you you shouldn’t have any problems installing the two SSD drives into your system. I my self have a 2012 mini with 2 Samsung SSD’s as a media server and its my backup server using two external HD’s. The SSDs are setup as a dual drive config to gain the maximum storage.
The only issue you might encounter an issue is the OX-X your 2009 is running may not offer the needed hardware drivers for your newer 2012 mini. You may want to first backup anything on the boot drive and then reformat when connected to your still running 2012 system before you swap things around.
The only thing you might want to review is your SSD’s specs. Your SSD’s maybe just SATA II (3.0 Gb/s) Vs the faster SATA III (6.0 Gb/s). If your boot drive is a smaller 256 GB drive you might consider getting a newer drive to squeeze out the maximum performance.
这个答案有帮助吗?
得分 1
2条评论:
Here's the needed kit Mac mini Dual Drive Kit to add the second drive, and here's the guide 为您的 Mac Mini 2012 晚期款 安装双硬盘模组
完成的
I actually have a pair of 1T SSD drives that I will be transferring over to my 2012 Mac mini from my 2008 Mac Pro. Things are taking long though. I anticapating the arrival of my Mac mini kit and dual hardrive enclosure that I bought along with an external Akitio thunder2 Pcie chassis as well.
完成的
添加一条评论
添加你的答案
Samuel Mathews 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 36
