跳转到主内容
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
116 个问题 查看全部
fireoscaptiveportal generate_204 Setup Firestick
I’m trying to setup my new Firestick but it keeps getting stuck on the joining network page. The screen shows a white box and the message includes a link to fireoscaptiveportal generate_204
Any ideas on what to do please? My internet is working perfectly on my other devices.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 72
18条评论
Any solutions to this issue?
完成的
I get the same screen, but in the middle of watching something. Rebooting everything seems to help but is really annoying.
完成的
net::ERR_NAME_NOT_RESOLD
完成的
How to setup my WiFi Repeater?
完成的
What is the username and the password for my WiFi Repeater
完成的
显示更多的13条评论
添加一条评论
7个答案
已选择的解决方案
which type of frequency your wifi works on? 2.4 or 5 ghz?
If your router is syncing the two then there might be your problem (you should change the setting of your router to get out 2 ssid one for the 2,4 and one for the 5ghz and then you try to connect on one or the other to see which one works
这个答案有帮助吗?
得分 47
11条评论:
I do not want to change any settings on my router as ‘all’ other devices and services appear to work without an issue, as does another fire stick on another TV, any other ideas?
Thank you,
完成的
I agree the television works perfectly with the aerial by I want to use the other facilities as well
完成的
i reccently changed passwords on my wifi
完成的
i changed password recently, cause could be time of day or due to my amount of activitie?!
完成的
This answer is completely useless and does not address the actual issuel
完成的
显示更多的6条评论
添加一条评论
It’s the BT home hub smart setup. Go into advanced settings on the router and disable smart set up. Everything will work perfect after!
这个答案有帮助吗?
得分 7
6条评论:
je ne comprends pas votre langue !
完成的
i dont know how! everything wAS Fine, until i changed psw"s all other devises work ok!
完成的
it tells me ; access blocked!
完成的
Press the three lines on your fire stick remote and then press select and forget the network then find the network again and enter your password to log into your router again and go to the home screen on the fire stick and they should work if it doesn't work the first time repeat the process until it does this worked for me today on January 24th 2022 good luck
完成的
Yea. Worked on reboot of the device
完成的
显示更多的1条评论
添加一条评论
i made the stick “forget’ my router and reconnected and it worked
这个答案有帮助吗?
得分 6
12条评论:
I tried but that didn't work either. I even tried with phone hotspot but it didn't work
完成的
it is working now thanks for help
完成的
Just do forgot network and reconnect it. It will work. I have did and successfully connected.
完成的
Same issue .. My solution was forgetting the network, resetting the firestick and reconnecting to the network again :) .. works fine now!
完成的
by resetting the fire stick you mean ?
完成的
显示更多的7条评论
添加一条评论
Unpaused firetv please I want to watch tv
这个答案有帮助吗?
得分 2
添加一条评论
bonjour, pour que je comprenne , il faudrait, m’écrire en français, je ne comprends pas votre langue, que vous chercher à nous imposer, tout le monde ne parle pas anglais, merci de revoir votre copie
这个答案有帮助吗?
得分 1
2条评论:
bonjour, je voudrais que nous donne la solution pour installer OQEE by free avec amazon fire tv stick qui rend soin disant une ancienne tv en en téléviseur Smart , merci
完成的
eu ce problème aussi le 24 janvier 2022. SOLUTION : Réinitialisez le Firestick en usine et cela fonctionnera. Et si vous ne savez pas comment réinitialiser, maintenez simplement la flèche droite + le bas de la télévision (en bas) pendant 10 secondes et il vous demandera de réinitialiser le firestick. Merci
完成的
添加一条评论
bonjour
moi jai le meme probleme. sauf que jarrive pas a me connecter a internet. cest ca le probleme. je suis dans 1 hotel. le meme depuis 2 mois. ca fonctionnait parfaitement puis soudain bam non!. le portail de lhotel saffiche, je peux entrer mon email mais quand je fais connection: il mamene a la page blanche err not responded. fireportal generate 204. jai tout essayé: débrancher la firestick, vider les caches, vider les cookies, essayer de passer par silk( mais je suis pas capable puisque je nai pas dinternet). a laide!!!!!!
这个答案有帮助吗?
得分 1
添加一条评论
No puedo usar mi fire tv porque no conecta el internet
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 37
过去 7 天: 360
过去 30 天: 1,207
总计 57,568
