跳转到主内容
My iPod only works when its charging.
My iPod 4th generation nano only works when plugged in. I have left it plugged into ac power overnight, and in the morning it shows it's complete, but when I unplug it, the screen goes dark and the device loses power. When I try to turn it on by holding the play button nothing happens, I try to reset it by holding the menu and center button for 6-30 seconds and also nothing happens. The device was used rarely from purchase and has been sitting without a charge for at least a year. I can listen to music while it's plugged in and "charging" but when I disconnect it from the ac power cord its a dead duck. If anyone can help me I'd be greatful.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 21
3条评论
i have same problem
完成的
my brand new shuffle charges fully when plugged in but won't turn on when detached from charger...
完成的
@paschal smith i... dont think you can get a brand new shuffel. you probably got scammed and the battery is cooked.
完成的
添加一条评论
3个答案
最有帮助的答案
Reboot it while it is plugged in. That's what i did and it worked.
这个答案有帮助吗?
得分 8
13条评论:
How u did this bro
完成的
Hold the Menu and select buttons at the same time for 8 seconds or until it turns off. Once you see the apple logo, it's been rebooted.
完成的
thanks was about to throw it in the trash back to normal ;)
完成的
Thank you for sharing!!!
完成的
thanks dude I was 2 seconds from letting it meet it's maker!!!!!!!!!!!!!!!!
完成的
显示更多的8条评论
添加一条评论
Hey Ryan, sorry to hear about your Nano. Sounds like a dead battery to me. Your best bet would probably be to replace the battery with one of our battery replacement kits. Unfortunately, replacing the battery requires some soldering, but if you're game, give it a shot! What better way to learn, right?
Hope this helps! Good luck, and let us know how it goes.
Replace a battery compatible with a fourth generation iPod nano model A1285. 230 mAh.图片
产品
iPod nano (4th Gen) Battery
$13.99
这个答案有帮助吗?
得分 5
2条评论:
and this is a hard fix..i gave up and sent mine to oldturkey!well done nick
完成的
I had the exact same issue - probably used the thing less than 10 times since I bought it, and when I pulled it back out to take a trip last week, it wouldn't charge. It really chaps me as it's still in like-new condition and was certainly not worn out! And Apple wants something like $60 to replace the battery, what a scam...
完成的
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
得分 1
1条评论:
I just took my iPod 4th gen apart and there was corrosion on the board so I figured I may as well clean it. Will update when I see what happens!
完成的
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 55
过去 30 天: 203
总计 85,667
