跳转到主内容
Why Does The Error Code F17 Mean On A Fisher And Paykel Fridge
I have a fisher and paykel fridge and ocatonally it will beep when you open it and on the screen it will show a wrench and the error code F17. This is for a Fisher And Paykel fridge not a Whirlpool fridge they did not have a Fisher And Paykel fridge for the device at the time this was made.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @samuraisammy ,
Here’s a link to the service manual for a RF201A. Hopefully is it a close enough model to be of some help.
According to the manual on this page:
Fault Code 17
Reason: The FC fan is drawing less current than is expected. Either the wiring is open circuit or the fan is faulty.
Primary Action: Check the FC fan wiring and connections at both the fan and the power module
Secondary Action: Check the fan. If faulty, replace
Here is the page that shows the FC (Freezer Control) fan.
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
1条评论:
@jayeff Ok ill give it a try
完成的
添加一条评论
Well this is a hoot. Your error code is listed as a freezer fan issue
but next to ALL the error codes it says:
You will require a Service Technician to assist
https://producthelp.fisherpaykel.com/nz/...)
This is a crock! Let me do some more research, who do they think they are? John Deere or Apple (only WE can fix your machine.
Please give me your exact model number and I’ll see if we can’t find some better help.
Her’s where model numbers are located:
https://producthelp.fisherpaykel.com/Man...
UPDATE
You must be from down under
Looks like it is made by Sears and they do offer parts.
See if this video helps:
https://www.youtube.com/watch?v=r7zEunxy...
这个答案有帮助吗?
得分 1
3条评论:
@mayer Hi thanks for the help the model number is RF201ADUX1
完成的
I have the same problem with my fridge RF195ADUX1, changed the fan and control panel and still showing the same problem, F17. Any suggestions?
完成的
@shahramdowl6921
Is the fan operating?
If not is there 12V power getting to the fan from the power board?
If not it may be a wiring problem between the power board and the fan
Here's the wiring diagram from the service manual (yes it is for your model as well, check p.1 for models shown by this manual)
You may have to simulate that the doors are closed for power to be applied to the fan as it is turned off when a door (either door) is open
完成的
添加一条评论
添加你的答案
SamuraiSammy 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 28
过去 30 天: 114
总计 8,411
