跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
Why won't my iPod Touch be recognized by iTunes or my computer?
So I have a iPod Touch 1st Gen. & I connected the firewire charger to the computer and the iPod Touch made a 'beeping' sound and its charging but nothing happened on the screen and it's not showing on iTunes. I can't reinstall/update iTunes because I don't have admin rights...
Plus, there's no other plugins where a firewire charger can be plugged in.. & my iPod Touch only works with a firewire charger soo.. Getting a USB cord won't do. /: Please help. > <
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
If your iPod touch only works with firewire, that could mean that you have a bad battery. Firewire is higher (8-30 volts) than the USB voltage of 5 volts nominal. You can use Firewire to charge only. It will only sync over USB. Check on here for a list of iPod compatibilities with firewire. Good Luck
iPod Touch 1st Generation Battery Replacement
[关联产品丢失或禁用: IF132-005]
这个答案有帮助吗?
得分 1
6条评论:
So do I buy a USB cord? I used like 3 different kinds & it still didn't sync.
完成的
It can only sync with USB. You can charge the 1st gen iPod touch with Firewire but that's it. What happened to the iPod that it stopped working with your USB cables? My instinct says that you need a new battery. When you connect your USB cable and your iPod does not respond, it is POSSIBLE that this is caused by a bad battery.
完成的
So I need to get a new battery? D: I don't think I can afford one. > <
完成的
Yes you do. I definitely would start there. The price is really not that bad if you shop around on places like this The quality of course will not be as good as if you would by it on ifixit....;-)
完成的
Hahah. What stores do they sell them at? O: And how much? If ifixit is an online store its off the list lol.
完成的
显示更多的1条评论
添加一条评论
my ipod 1 gen wont sync i went to itunes and thats what the screen says to do so i did it and nothing happend what do i do ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carmela 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,354
