跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Sound problems with I phone?
Heres the problem: I did an update for my iphone using a usb cable and itunes on my computer. Once the update was finished, I unhooked the device. Every since then, my phone has been saying "this accessory is not optimized for this device" and I can not get the volume to work right. When I try to change the volume, it is blank under the word "ringer" and the speaker on the screen. Does anyone know how to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This can be either a Hardware or Firmware issue. You are not alone as there are hundreds of other iPhone users experiencing the same issue. Try reading this on an apple forum. Some possible fixes include -
- Plugging earphones in and out of headphone jack about 20 times. Some iPhones are shipped in "earphone mode" and need to be reminded that THEY ARE NOT
- Clean out dock port (possible dust has gotten inside and corroded port making iPhone think it is connecting to something continuously ) and completely restore iPhone. Use a dry toothbrush (something small with bristles to do the job) or dry compressed air. DO NOT BLOW on it with your mouth as saliva may get into it and make it worse.
- Disconnect the battery for several seconds and reconnect, this will physically reset ALL electronic parts of the iPhone. Repair Manual HERE.
- Upgrading to the new/latest iOS
If none of those options have worked then you will need to either take your iPhone back to apple for a replacement (if still under warranty) or replace the dock connector, Repair Manual HERE
Hope this helps :)
iPhone 3GS Battery图片
指南
iPhone 3GS Battery Replacement
难度:
中等
20 - 30 minutes
iPhone 3GS Dock Connector图片
指南
iPhone 3GS Dock Connector Replacement
难度:
中等
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Steven Kelley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 515
