跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
Use a Core Duo LCD on my Core 2 Duo MacBook?
I'm getting tonight for cheap a Macbook Core Duo that I'm scrapping for parts to fix a Core 2 Duo Macbook.
Anyone know if the LCD screen / display housing from the Core Duo would be compatible with a Core 2 Duo?
I know the keyboard is compatible... wasn't sure about the display. I have to replace a bad display, damaged display housing, and a keyboard.
Thanks for the help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
The screen itself is exactly the same. The antenna cable may or may not be different (3 connectors instead of 2?) You can always switch the Airport card, if that means you don't have to bother swapping the Airport cable. And the inverter cable will likely be different as well (4-wall instead of 3-wall), but like I mentioned the good news is you can swap that stuff out from your old machine to the new, so I don't think your situation presents any dealbreakers.
这个答案有帮助吗?
得分 7
4条评论:
Thanks for the info :) +1 for the help.
New to this site btw... very impressed on a lot of levels.
Seems like a great community.
完成的
You can actually use the two antenna cables on a three pin airport. Just connect the outer ones an leave the middle one blank.
完成的
Thanks Remacberlin, that's good to know! Is the signal strength just as good when the antenna is connected that way?
完成的
Thanks for the tip remacberlin. Leaving the middle pin black on the airport worked like a charm.
完成的
添加一条评论
添加你的答案
Phil Laurent 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 298
