跳转到主内容
加入维修社区 - 创建账户
雪铁龙汽车的修理和支持指南。
The car doesn't start
my Citroen c8 doesn't start?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Could we possibly get some more information?
完成的
For instance--does the engine turn over?
完成的
the engine doesn't turn over
完成的
Since you are really not telling us anything about what your car does or doesn't do. Start witht he basics. Do you have any battery power? Do your dashlights come on? Do your lights come on? Do they go dim when you try to start your car? You need to give more info if you want a definite answer.
完成的
添加一条评论
3个答案
已选择的解决方案
With a broken timing belt you will have:
bent valves
damaged pistons
possibly bent con rods
Or just a useless timing belt. Do not try cranking the motor over (might lead to all issues mentioned above). Take it to a capable garage!
这个答案有帮助吗?
得分 4
1条评论:
Extremely good advice--you can total a engine with a bad timing belt. +
完成的
添加一条评论
Insert your car's key into the ignition switch and turn clockwise until you hear sounds from the engine bay.
这个答案有帮助吗?
得分 2
1条评论:
the timing belt is broken and it damaged the engie
完成的
添加一条评论
If you have a keyless push button ignition it requires you press on the brake to start. There's a brake pedal switch that performs this function which is a common problem and quick repair.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
solomon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 12
总计 2,080
