跳转到主内容
Cursor moves automatically on screen
We have checked for liquid damage in keyboard and trackpad. Sensors are ok. Current os is lion. System pref settings are ok. Cursor starts behaving erratically and move here and their without touching trackpad at all. Please suggest a solution.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
You mention that you "have checked" for water damage. Did any liquid spill on the machine?
完成的
No, no spill on the machine.
完成的
Could someone be playing a prank on you with a bluetooth mouse or with screen sharing? I have done that a couple times for a laugh.
完成的
添加一条评论
1个答案
已选择的解决方案
This is a fairly new machine, Warranty?? ( no water damage)
If not under warranty having already checked everything ( connections, resetting system preferences etc).... you could replace the trackpad.
However this may be a problem caused by Lion. ( i have heard of people complaining about this issue with Lion and the latest update i don't recall if it was for this type of machine). See if an apple brand external mouse does the same thing.. if it does take it in for apple support if you still have a warranty.
You could also boot the laptop form an OSX DVD ( Snow Leopard that came with it) and see if it still has this problem...... go from there.
这个答案有帮助吗?
得分 4
4条评论:
Yes, it's under warranty...
USB mighty or magic mouse runs ok.
Well said.. trackpad ordered.
Will update after changing
完成的
well if it's under warranty and as you said their is no liquid damage, you can just take to your local apple store and they will fix it at no charge....... ( not sure if you have an apple store near you or not).... if not you can call apple, and they should at least be able to tell you of an authorized service center near you.
完成的
The problem only got solved after changing the trackpad. Thanks
完成的
Please mark Brians answer as "accepted" for future reference.
完成的
添加一条评论
添加你的答案
rkhera 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,168
