a spark coming from a red wire
help a spark coming from a red wire and when I turn the screen on and a minute later the screen goes completely off
The red wire plugs into the front I/O panel, yes? I would recommend inspecting the front I/O board, The motherboard (the components the cable plugs into) and then then the power supply. The power supply is the most likely to break so I would inspect that first. Make sure to let it set for 2 days to allow the high voltage to discharge and wear an ESD strap when working on it (as the manual says). If the red wire is part of one of the cables that go to the power supply, check the power supply and the surrounding components where the cable was connected for damage. Patch and replace components as needed.
If you have more information about what happened and where exactly the spark was, then that would be helpful for a further diagnosis.
WARNING: Powers supplies contain high voltage that can be lethal, do not open the power supply unless you know what you are doing.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 146
Where is that red wire located? What does it connect to?
由 Naples 完成的
IDK where this is for my friend it happened last night
由 Nicholas Parrish 完成的
@phoneuser0809 without seeing where the wire comes from and where it goes to, there is not a whole lot that we can tell you. Get some pictures of all of this and post it with your QUESTION 在已经存在的问题里加入图片
由 oldturkey03 完成的
