跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 个问题 查看全部
Water damage, no backlight, replaced LCD but still doesn't work?
Hi there,
My iphone had water damage (you could see it in the camera and in the LCD). Everything was fine except there was no backlight. So I opened it up and the indicators on the logic board were still white.
So I ordered a new LCD on ebay and replaced that, and after replacing it, the backlight still isn't working. There doesn't appear to be any corrosion or anything on the logic board or other connections, and the indicators are still white. Should I give up or are there more steps I can take to get this phone working?
Thanks for your help in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
if this is the case then it may be the 6r8 coil or part of that pathway. take it to a phone shop and see whether they do that repair.. or buy the part from ebay for $5 solder it yourself or if the path is damaged you'll need to to solder a wire between the coil and the lcd pin (1 or 2 ) i forget now..but google backlight iphone 3gs and there are millions of how to guides on youtube that should help.
这个答案有帮助吗?
得分 3
1条评论:
You also might want to look at this guide 修复iPhone 的进水故障 and clean your logic board and connectors of the corrosion that you noticed. The guide is for the 3G but essentially shows you what you need to do. Follow these guides to get to your logic board....
完成的
添加一条评论
Hi,
Once water damaged, there is lots of things which can go wrong on this phone.
First of all, check the LCD connector (on the iphone logic board of course). Ensure the pins are all clean and not shorted. If a doubt, use a thin needle to clean between the pins.
Then, check if all these pins are well soldered to the board. With the needle try to move (gently) each pin to see it they are correctly attached. If one is moving then you will need to use an iron with a very thin tip to solder it back the pad. Due to the corrosion you will probably have a hard time to solder the pin.
Of course a good magnifier is needed to do a good job.
If the LCD connector is alright then you will need to remove the upper can of the logic board and check for shorted pins.
Good luck!!
Guile
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rachael 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 1,264
