2017 MBP black vertical bar flush against right side of display
There's no colorful lines or extra lines, it's just this black stripe — the backlight seems to work, whenever I press a little around the rim, there's discoloration. Is the LCD broken?
Sadly you do need a new display assembly ;-{
In your case the ribbon cable which drives the column of lines that are black have gotten damaged. Here’s a look of the T-CON board which is located within the body of the system. The two large ribbon cables carry the video singles to the LCD panel in the lid. One of these cables got damaged.
Here’s the needed part:
And here’s the guide 2016后期带功能键的13寸MacBook Pro显示屏组件更换
这个答案有帮助吗?
Darn... expected as much but still a bummer! Maybe I'll just use it as a desktop. Thanks for the response!
Sorry ;-{ A bang along the black antenna/clutch cover could have been the cause.
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 193
