跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Touch issues after screen replacement
Replaced the screen on my friend’s phone and everything’s working EXCEPT after it’s been on for a couple hours, swiping up from the bottom (for the control center) and down from the top (for the notification center) stops working.
I plan to open it up and check the connections but I just wanted to see if anyone on here is familiar with this specific issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
This is most likely a poor quality or defective replacement screen.
这个答案有帮助吗?
得分 2
2条评论:
i ordered the screen from ifixit, is this known to happen from time to time?
完成的
Yes, dud screens will always filter through. Contact iFixit support and they will take care of you.
完成的
添加一条评论
If you are sure that the screen is a reputed one, remove the screen flex and rearrange and install brackets(assuming if you missed it in case). Lock the flex cable carefully.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
thardee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 24
总计 212
