跳转到主内容
所有的苹果便携式平板电脑的全面维修手册。维修过程可能需要加热以及细心的撬动。
5766 个问题 查看全部
What is the best technique to remove a Shattered screen (digitizer)
After heating the digitizer, I use a thin metal pry tool to lift the screen and then a plectrum and alcohol to release the glue holding down the digitizer. I have tried putting packing tape, masking tape and 3M clear tape on top the screen to bond the splintered section together to get as much of the screen off in one go, as possible, but the tape does not hold the splintered sections in place.
Getting the screen off in one piece drastically reduces the repair time.
I am going to try some Gorilla Duct Tape next and am even thinking of even trying to bond a screen protector with UV glue
Does any one have any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Regular packing tape has never really worked for me. If a screen was really destroyed, I would use duct tape which worked well, but I would leave the edges (path of the heat gun) of the digitizer not taped. Doing that limited the amount of heat on the tape reducing the chance of a burning tape odor. I would then just manually remove what remained on the frame of the iPad. I wouldn’t recommend UV glue because it’s expensive and risky in that matter.
这个答案有帮助吗?
得分 0
添加一条评论
As the screen is shattered and no longer useful we can use force on three sides, except the side on earpiece. The best part for prying an iPad is having patience. Use the metal spudger for prying.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roland Chandler 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 24
总计 893
