跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
When I connect bluetooth volume lowers.
Volume lowers and I need to turn volume up, then I need to turn the volume up again.
I can find no wrong settings.
Update (01/17/2020)
I have checked every settings and checked for updates. phone and bluetooth device is at newest update.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
This is just a function of the software. The volume for headphones, Bluetooth devices, Siri, and onboard speakers all have different volume memories. The volume will always default to whatever it was the last time you used the device. e.g: Plug bluetooth speaker in and turn volume to 5, disconnect it from the phone and the main phone volume is at 3. When you turn up the phone (without the Bluetooth speaker) the phone’s volume will increase to 6, but after reconnecting the speaker it goes to 5 (the volume that speaker was last at) if you were to disconnect the speaker, it would go back up to 6.
这个答案有帮助吗?
得分 1
1条评论:
Yeah, but the issue here is that I can turn it on max volume and it will lower itself so I have to turn the volume up again. even though I have touch 0 buttons or volume up / down
完成的
添加一条评论
添加你的答案
nicolay.94 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 1,025
