跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
No Power to Optical Drive after Replacement
I am having an optical drive issue where I replaced everything except the laser and the daughter board since they are paired to the motherboard after that I am getting no power to my optical drive at all it won’t spin it won’t make a noise when i try to press the eject button and i triple checked every cable to make sure they are plugged in and i see no sign of damage on any cables.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did the old drive had power? If no, it could be the PCB which is broken.
Are you sure that you connected the PCB correctly? And is the new drive exactly the same type as the old one?
这个答案有帮助吗?
得分 0
2条评论:
It is exactly the same as the old one and yes it did have power before but it made a weird noise before now it doesnt make any noises at all
完成的
Hi Miguel,
Sorry for the late response! I think it's PCB related anyway as it looks like there is no power coming in. Could you test with the other drive again? And if possible, please measure if there is any power.
完成的
添加一条评论
添加你的答案
Miguel Lugo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 30
