跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Is the Audio Control and Power Button Replacement like the 5s?
Is the iPhone 5s Upper Component guide the same as for the iPhone SE? I realize it is a different part - just wondering what (if anything) must be done differently .
This is the guide I’m referring to: iPhone 5s 顶部排线更换
If not, then what is different?
I unfortunately damaged the cable during a battery replacement… completely my foolish fault, but now the flash doesn’t work at all.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There are some minor differences but nothing of any significance. Just write down any functional differences on a sheet of paper as you do the repair.
这个答案有帮助吗?
得分 2
1条评论:
I take pictures
完成的
添加一条评论
An additional NFC RF cable run along the top edge around the camera, ending on a screw post beneath the logic board. Otherwise it is very similar.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jozsef Szep 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 88
