Drain pump works but does not drain water
My washer will not drain water. It is an lg top loader. It keeps giving error code oe meaning that a hose is clogged. The house is not clogged and the drain pump works. I took it out and tested it and the motor is working and the Wiring is also. There is a lot of debris when I put it in self clean or when I drain the water by gravity. Can someone help me solve this issue. Planes and THANK YOU.
david flores what is the complete model number for your LG washer?
由 oldturkey03 完成的
You have comments turned off on YouTube? Wanted to see what the issue was. Mine is doing exactly the same thing. I have it all taken apart and was gonna just buy the new pump for the left side. That the side that's making the noise. It's the blade spinning.
由 Justin McMahon 完成的
Wait it was not working that whole time? From Jan 2020 to Oct 2020 when you posted the YouTube video? Why didn't you change the pump?
Gotta say, during Covid I've been seeing masks getting stuck in the tub-to-pump hose and between the tub and drum. They are small enough to slip between the drum and the tub at the front, where there's a 1/4" gap between the two. So if you've replaced the pump and it's still not working, that'd worth checking. The hose in question is the one that attaches to the bottom of the outer tub on one end, and the drain pump housing on the other, on LG's it's usually secured to the tub with a screw clamp.
Another thing that's worth checking is your drain hose installation. If it's too far down the standpipe this can cause issues with draining. Ideally you want the drain hose to only stick down about 4-6 inches into the standpipe. Sometimes I see them sitting several feet down, with the opening down in the standing water, and this can cause the unit to not drain properly.
由 Marcus Friberg 完成的
IF on the other hand someone has a viable solution, I am all ears...so please do us all a favor and end our misery and post the solution...
由 D Cobes 完成的
显示更多的3条评论
