跳转到主内容
加入维修社区 - 创建账户
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
How to replace SIM module?
Hi Guys,
I tried to replace a SIM Module for iPad 1 Gen, but it can't find the 3G signal yet, I would like to know whether the logic board locks the module while replacing the modules or not, if yes, how to unlock it?
Thanks a lot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I would bet the IMEI was blocked somehow or the antenna is bad
Check the IMEI, if it is blocked, the only legal way to fix it is to swap the logicboard(I would suggest changing it, but it turns out it's not legal, even if it is done as a personal fix and you aren't selling your device, DO NOT DO THAT!)
By all means if it isn't, the 3G antenna could be bad, change that
If it still doesn't help, your only hope is a logicboard(legalities changing the IMEI)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
apple5808 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 1,254
