跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
MBP 2017, black bars across screen, display failure.
Hi
My 2017 MBP has been developing a display fault resulting in a large black bar across the screen. This device was purchased refurbished at the start of 2018, and thus the 1 yr ltd warrenty is no longer active, but my statutory rights still stand (EU). From some research here and elsewhere it seems to be common, but not common enough to warrant a recall program.
The device is currently with an AASP, and according to them the GPU or another display component has been fried due to inadequate cooling.
The question is, would you consider this an inherent fault with the device? and has anybody sucessfully had an issue like this rectified without paying for it?
Video:
https://youtu.be/jdgd40N_n_U
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
This issue was covered under a warranty exception after presenting Apple with a tech report / repair quote
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
You need to hook it up to an external monitor to confirm the diagnostic.
这个答案有帮助吗?
得分 2
4条评论:
AASP confirmed this using an external.
完成的
Fine, as long as you saw it and not just them.
完成的
More often the internal displays T-CON board has this issue which won't show up on an external monitor. I would double check is you have the grey bar on it.
If the external's image is clean then you'll need a new display assembly, as the T-CON is part of the display via a set of ribbon cables.
As far as fault. In my option this is a design failure as the T-CON board is placed near the heat sink cooling fins. The lack of cooling either because the fans failed or the vents where blocked so air was not able to flow across the fins would be the root cause.
I would press for a warranty exception! As Apple should take responsibility.
完成的
@danj Thanks for your advice, they did indeed take responsibility for this issue.
完成的
添加一条评论
添加你的答案
padrick 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 391
