跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Used a metal to unlock display cable, sparked and Mac restarted. Dead.
I suddenly got a red vertical line in the display and then I opened the Mac, undid the display cable with a metal tool, there was a small spark ⚡️ and then my AirPods disconnected, I opened the Mac and see it has been restarted (with colorful images) and then I enter into the Mac, everything gray, normal windows where there, like logos are colorful but no desktop picture and all plus windows were Weird sized..! I restarted but it wasn’t restarting so I long press the power button.
Tried turning in, but no luck, opened, disconnected the battery and reconnected, fan works sometimes and the trackpad clicks.
when connected to the MagSafe it’s orange
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
For as much as I can sympathize for your loss it’s quite clear you don’t have the skills to fix the fault or you wouldn’t have caused it in the first place by using metal tools on a running board which is about the best one can do to cause extensive damage. Taking your Mac to a shop/lab into component level repairs would be the best you can do to get it fixed, or contact Apple if you prefer.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
StanlyYa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 66
