跳转到主内容
加入维修社区 - 创建账户
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Display isn't working and won't work with an external display either
Hi guys!
My first post on ifixit so forgive me if I don’t cover all the details.
I’ve got a 2011 Macbook Pro 15inch which recently packed up on me because the battery had expanded, I replaced the battery and the battery itself works fine, powers on and I hear the chime.
The issue is that I see nothing on the display, nor anything when I try to connect from minidisplay/thunderbolt to HDMI, i’ve tried with an adapter and with a direct cable.
I initially tried taking the display cable out and putting it back in but nothing, after it didn’t work on the external display I realised the issue was bigger than that. It also does this weird thing where i’ll turn it on, the fans will spin and then it will turn off again, then I power it on a second time and it stays on, but again nothing on the display or external monitor.
Could this be a GPU failure? If so how would I go about repairing it and if it’s not what else could it be? Would really appreciate some help on this guys. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
GPU failure is the most common problem with this model. DosDude wrote a little program that solves it. I have used it on many of these machines. It does limit programs like PhotoShop but otherwise restores this model to a working condition.
https://gfx.io
For permanent fix go here:
http://dosdude1.com/gpudisable/
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Usman Ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 104
