跳转到主内容
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 个问题 查看全部
Car will not start, no clicking or cranking. Replaced battery and star
I have a 95 Camry not starting. I found an exposed wire on the starter and replaced with a remanufactured part. It drove for a few days after that just fine but now won't do anything again. There was some acid seeping on the top of the battery so I was able to replace it free under warranty. I don't get any clicks or crank when I turn the key. Wiring to the starter all looks good to me. What's next? Ignition switch/ cylinder? Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Check the battery connections, they may have loosened some since it was replaced recently. Retighten all connections then check to be sure the battery has voltage enough to start the engine.
这个答案有帮助吗?
得分 0
4条评论:
It was replaced this morning and I tightened it all back up. Brand new battery but I don't have a gage in the dash.
完成的
When turning the key to start are there any dash lights or indicators showing?
完成的
Yeah, dash lights come on and it dings if the door is open.
完成的
Re check all connections and fuses.
Also check voltage of battery 12.8v is a full charge 12.2v is considered flat and may not be enough to start.
完成的
添加一条评论
Hi @dschnur72
Check your fuse box for a blown fuse. There are usually two boxes one under the hood and another somewhere near or under the steering wheel. After taking the cover off, you should see a diagram of which fuse it could be. While checking for blown fuses, give the starter solenoid a couple of good whacks with a small tool to see if that’s the problem.
这个答案有帮助吗?
得分 0
1条评论:
I haven't gone through all the fuses yet but replaced the starter relay. It looked good but I already had the part so I put the new one in.
完成的
添加一条评论
添加你的答案
Daniel Schnur 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 24
总计 753
