跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Second internal drive not initialised
Hi there!
Been runing my Macbook Pro 13’ mid 2012 for a while with a Samsung 840 EVO SSD and a Toshiba HDD as replacement for the optical drive.
Now I changed the optical one for a Samsung 860 QVO and it just says drive not initialised…as external drive it works just fine so whats the problem?
Disk utility doesn’t really do anything.
Is it possible I can’t run this SSD as optical replacement or what’s the deal?
Attached a couple of screenshots:
Thanks in advance!
Phil
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
it’s an electronic issue…the cable that runs on the logical casing caused an error…
Just put some tape underneath it and problem solved!!!!
happy days!
这个答案有帮助吗?
得分 1
添加一条评论
The cable also gets damaged on the top ledge. I use 3M extreme mounting tape to protect it.
这个答案有帮助吗?
得分 1
添加一条评论
Some Macbook Pro’s have an issue with the Optical drive SATA port. While the 2012 models had been fixed I wonder if the newer Samsung drives interface driver has a problem. You may need to update it. The 870 EVO Plus had a driver issue which Samsung has fixed.
Let’s try this take your current 840 EVO out of the HD bay and put your new 860 QVO in its place. Are you able to install macOS onto it via Internet recovery?
If that works that is pointing to an issue with the Optical drive SATA port.
In anywise do make sure you have the newer HD SATA cable as its known to have issues! Place some electricians tape on the uppercase where it crosses over and don’t crease the cable! Instead create an arc using a BIC pen ink straw (or similar ink straw, empty) to help form the radius.
I haven’t encountered issues with the Optical drive’s SATA cable but you might want to give that a try as well if the HD bay works.
这个答案有帮助吗?
得分 0
1条评论:
thanks mate but a bit of tape fixed the whole thing...do you reckon it'll be better to put the new one (860 QVO) into the HD bay?
One SSD is meant to hold my tunes ( about 800gb) and the other one to run the system and hold apps, pics etc.
Currently I'm restoring my itunes library from icloud and the macbook is steaming...
完成的
添加一条评论
添加你的答案
youthed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 56
