跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
iMac screen won't turn on unless power cable is at a certain angle.
If I put the power cable in all the way, the fans will run (at full speed), but the screen will not turn on. If I move the power cable out a little bit, it will boot with the screen on. Once I have it booted, I can move the power cable all the way in. Does this call for a replacement power supply?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I’d start with a new power cable. much cheaper to boot.
这个答案有帮助吗?
得分 3
2条评论:
I’ve tried that.
完成的
Why are you messing with it after it runs OK?
完成的
添加一条评论
添加你的答案
bone apple tea 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 67
