跳转到主内容
Repair and disassembly information for amplifiers in home audio systems.
117 个问题 查看全部
VSX819H amp wont enter service mode
Hi, My pioneer VSX 819h went into protection mode. It now won’t enter service mode. I’m following the service manual. The only thing it does is turns on for 4-5 secs when pressing power button+adv-surround which according to the service manual is used for clearing the error counts. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Until you resolve the protect mode, the amp will continue to work as you see it. Protect usually indicates that there is a short in the output section and the amp shuts down to prevent further damage. Since this amp uses discrete transistors for outputs, check each one for a short. Once found, change the entire pair (2SD and 2SC transistors) and any other components in the area that are effected.
Dan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ThreeTwoBravo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 158
