跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
Has she finally given up?
Hi…
So, on returning home one evening i noticed my Imac had shut itself down of its own accord… (i had left the computer on when i left in the morning…)
Then upon trying to turn her on (phrasing) she began to boot till about 2/3’s the way up the loading bar, then the machine turned off completely… this happened on every attempt i made to turn it on…
It will however load up in recovery mode and also in target disk mode
When i tried to boot it up in Apple Diagnostics, it came up with the ‘!’, so i am leaning to the fact there is a hardware issue, but the harddrive is viewable on another mac in target disk mode… so it can’t be that? Or?
Does anyone have any solutions…?
HEELLLPPPPP?
in hope,
Paul
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sadly, your dedicated GPU has failed!
Running Target Disk Mode only leverages the CPU intergraded graphics (IG) engine. while your system trying to boot up starts off running the IG, during the boot at 2/3 mark the system flips over to the dedicated AMD graphics card (DG).
Here’s the steps to replace it: iMac Intel 21.5" EMC 2389 GPU Card Replacement
Getting a new part is getting hard and used boards are iffy! You could try baking (or heat gun) your board to see if you just have a cold solder joint.
But before you go down this path make sure you have an external backup of your data.
这个答案有帮助吗?
得分 1
添加一条评论
Try boot to a mac os install USB
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 116
