跳转到主内容
LCD NO Backlight - Extra Monitor Works FINE - Backlight Randomly Shine
NEED FOR SURE ANSWER IF POSSIBLE : )
My MBO was working just fine had fan noise then then went to sleep mode then when I attempted to wake it up the backlight was fully off i reseted everything sometimes randomly the screen lights up for a few seconds then back off but once in a blue moon.
What can this be? It works with external monitor just fine keyboard lights up and all.
I CAN SEE with a flashlight sideways everything just fine but no backlight.
What can i test / check to see what the issue may be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I am experiencing the same issue, however i just replaced the inverter, and my i sight and my keyboard led is working just fine, this is becoming very frustrating... not sure where to go from here
Thanks
完成的
are you sure about the connectors/wires?
are you sure your left IO board produces correct voltage?
https://d3nevzfk7ii3be.cloudfront.net/ig...
完成的
添加一条评论
1个答案
已选择的解决方案
Since you can see the the desktop dimly your most probable failure is the LED driver board. Here's how to replace it, but check your connections first: MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LED Driver Board Replacement
Here's the part: MacBook Pro 15" (Models A1226/A1260) LED Driver Board
MacBook Pro 15" (Models A1226/A1260) LED Driver Board图片
产品
$44.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Marlon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,937
