跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Why isn't my mac charging/ SMC not resetting?
I have a 13 inch, mid 2012 macbook pro. It is plugged in but not charging (although it is keeping it at the same charge). The magsafe light is green even though it is not fully charged. I attempted to reset the SMC using the method in which you turn off the mac and press control, option, left shift and command at the same time but it did not reset (I tested this by changing the energy saver settings and then attempting to reset the SMC. I then checked the energy saver settings and they did not reset). I also tried using a different charger. Any Ideas how to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
When you pressed the control, option, left shift and command keys did you also hit the power on button?
Try a PRAM reset. p, r, command and option key hit the power on button and continue to hold keys till the third restart.
Next, let’s take a look at the status of that battery: use this little jewel of a program and post your results:
https://coconut-flavour.com/coconutbatte...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Luke Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 653
