跳转到主内容
非一体化电脑称之为台式机。
2133 个问题 查看全部
Just built PC (specs in description), but no post, display, or bios
ROG STRIX B450-F Motherboard
ROG STRIX RTX 2070
1tb Samsung evo ssd
500 gb Samsung evo SSD
2 x 8 gb tridentz rgb ram
corsair h100x
Cablemod C-Series Corsair cables
Corsair CX750M PSU
NZXT H510 Eite case
Everything is plugged in, everything that needs to be routed into the psu is plugged in. The Motherboard and gpu leds are lighting up, but fans aren’t spinning and I can’t get a post no matter what I do. I’m thinking it’s a compatibility issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What RyZen CPU are you using?
Unplug:
* SSD’s
  • Mouse and keyboard
  • Try no RAM then one RAM module at a time in different sockets.
* Look for a loose screw that may be causing a short.
  • Troubleshooting is always a process of elimination.
  • Fans spinning, anything on screen?
这个答案有帮助吗?
得分 2
1条评论:
Hi @ gibbery,
Here's a link to the motherboard's supported CPU list.
Check if your CPU is on the list.
完成的
添加一条评论
添加你的答案
gibbery 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 90
