跳转到主内容
苹果于2019年5月发布的第七代iPod touch。这款型号搭载可达256 GB的存储和A10处理器。型号A2178。
37 个问题 查看全部
I dropped my iPod for the 1st time now screen doesnt work
I dropped my brand new iPod for the first time now the screen is black and is backlit a little bit, and it wont turn on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
my ipod shows a white and gray screen and won't turn off
完成的
Discharge ? STUPID. You need to be permanently banned from making ANY kind of comment. Regardless of what it about or what type of Q&A website it is
完成的
添加一条评论
6个答案
最有帮助的答案
This happened with my iPod touch 7th Gen, i thought the LCD broke too. Waited for it to discharge then it booted up normally after. If that does not work, replace the display (or have it replaced)
这个答案有帮助吗?
得分 2
添加一条评论
Press and hold the Power button and the volume down button at the same time. When the Apple logo appears, release both buttons
this is what the tech chic told me to do, and it worked, twice now. Good luck!
这个答案有帮助吗?
得分 2
1条评论:
Thank you! This helped me get it up and running. I still have vertical gray lines, but it works.
完成的
添加一条评论
You broke the lcd. You can get this repaired via a new LCD/Glass. It’s not easy for a beginner but my shop charges $69.99 for it so it’s not crazy expensive to have a profesional do it.
Try a soft reset first holding the power and home button together for 10 Seconds.
这个答案有帮助吗?
得分 1
1条评论:
Hi Dustin, where is your shop? My iPod Touch 7th Generation LCD is unresponsive to touch, and I need it fixed. I'm more of a beginner, and I don't want to mess this up. How can we communicate, so I could get this fixed?
完成的
添加一条评论
Hey Liam, I’m not the best at technology repairs, but by the symptoms that were posted, the LCD Data ribbon came loose, not the backlight ribbon, which explains the working backlight. I would say your iPod touch is probably fully working, just open it and firmly but gently resocket all the display ribbon connectors in place and test the device while its open. If it were to therefore work flawlessly albeit opened up, that would solve your solution without spending $60+ USD. If not, replace the display for the 60 bucks USD and end your frustration. Good Luck to you and yours, Austin.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem. It was fixed by waiting until the iPod was discharged and then pressing the upper button and the quieter button for 10 seconds. Then the display worked again and it showed me that the iPod was discharged. After that I could charge the iPod normally and it worked fine untill now.
这个答案有帮助吗?
得分 1
添加一条评论
Hi Liam:
Before I would open the iPod touch, I would follow the advice of Crazyblocks technologies and of Marcel. If this doesn’t help, I would open it and check if the LCD data ribbon cable broke loose, as The Bongo Guy suggested.
Steffen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
liam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 52
总计 3,866
