跳转到主内容
加入维修社区 - 创建账户
Nissan Rogue 是一款由日本汽车制造商尼产(Nissan)生产的紧凑型跨界 SUV(运动型多用途车)。Rogue 于 2007 年首次发布,作为 2008 款车型销售。
Replace blower fan motor
How to replace the blower fan motor on a 2011 Nissan rogue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Were is the location in heater blower
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Hi @islandboy99 ,
Here’s a link to the 2011 Nissan Rogue (S35) Service Repair Manual
Here’s an image taken from the Ventilation System section of the manual that shows the procedure to remove/replace the blower motor.
(click on image to enlarge for better viewing)
The other repair sections referred to in the removal procedure are as follows. The number after the dash is the page number in the section e.g. IP-13 = Instrument Panel section page 13
IP = Instrument Panel
MWI = Meter, Warning Lamp & Indicator
VTL = Ventilation System
HAC = Heater & Air Conditioning Control System
BR = Brake System
It is easier if you download the individual repair section and then view them that way.
At the bottom of the Document page that opens for each section there is a download link. Here’s an image to show where it is.
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
添加一条评论
Hello.
Remove the Driver Brake Pedal and also will help if you remove the Gas pedal.
After that youll lay on your back with flash light youll go underneeth the dash. on your left upper side youll se the blower motor.
Remove a screw top left of the blower motor.
Remove plug. ( it can be pain cuz you are upside down)
You need to twist the Blower Motor Left
This is the challenge here. After you remove the Blower motor it will not come ease. Theres is a Dashboard in your way a steering shaft. You need to find a way you remove the old (bad ) blower motor. Be creative.
After removing the blower motor(old) you need to find a way to the new one same way with you Braking the blower motor. its not easy repair.
Be patient.
Then reveres everything.
This is the way that i did it. :)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Paul baron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 63
总计 6,199
