跳转到主内容
加入维修社区 - 创建账户
苹果第三代智能手表,可选蜂窝网络版本,于2017年9月22日发布。
Apple Watch series 3 no touch after screen replacement
I recently replaced the screen on my Apple Watch series 3 Nike + edition. The screen comes on and the buttons work but there is no reaction from the device when I touch the screen. I have tried force restarting it dozens of times and it has changed nothing. The old broken screen does not work at all so I believe that trying to use the old digitizer will not work. Anyone have any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
Sounds like either the display assembly was defective or the cable connection from the SIP was not fully inserted and latched or was damaged.
这个答案有帮助吗?
得分 1
4条评论:
I have tried reseating the cables a couple of times and that hasn't changed anything, unfortunately, so I am beginning to wonder if there is another component that might be damaged or if the unit is now useless
由完成的
I went back and tried your solution and to my surprise, it worked! I can't believe it was that simple of a solution, thank you!
由完成的
What exactly was the solution? @Blake Russell
由完成的
@chi.areadj - Either the cable was not fulled inserted or the display unit was defective.
由完成的
添加一条评论
Blake what was it that you did exactly? I am having the same problem…I can’t get touch to work. The touch cable appears to be seated into the connector…I’m stumped
这个答案有帮助吗?
得分 0
1条评论:
Hi Jerrod, did you ever resolve the problem with your watch? I have the same issue.
由完成的
添加一条评论
For me the solution was update the firmware and after the touchscreen start to work fine.
这个答案有帮助吗?
得分 0
1条评论:
I purchased one of these sapphire screens for series 3. Screen works but in constant restore loop. Firmware upgrade fails each time also
由完成的
添加一条评论
I had the same issue after replacing my Apple Watch screen. The display worked, but touch didn’t. It turned out the digitizer wasn’t fully connected. After reseating the cable, touch functionality returned. Check the connections, and that might solve it!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Blake Russell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 31
All Time: 5,636
