跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
196 个问题 查看全部
Apple Watch series 3 no touch after screen replacement
I recently replaced the screen on my Apple Watch series 3 Nike + edition. The screen comes on and the buttons work but there is no reaction from the device when I touch the screen. I have tried force restarting it dozens of times and it has changed nothing. The old broken screen does not work at all so I believe that trying to use the old digitizer will not work. Anyone have any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Sounds like either the display assembly was defective or the cable connection from the SIP was not fully inserted and latched or was damaged.
这个答案有帮助吗?
得分 1
4条评论:
I have tried reseating the cables a couple of times and that hasn't changed anything, unfortunately, so I am beginning to wonder if there is another component that might be damaged or if the unit is now useless
完成的
I went back and tried your solution and to my surprise, it worked! I can't believe it was that simple of a solution, thank you!
完成的
What exactly was the solution? @Blake Russell
完成的
@chi.areadj - Either the cable was not fulled inserted or the display unit was defective.
完成的
添加一条评论
Blake what was it that you did exactly? I am having the same problem…I can’t get touch to work. The touch cable appears to be seated into the connector…I’m stumped
这个答案有帮助吗?
得分 0
1条评论:
Hi Jerrod, did you ever resolve the problem with your watch? I have the same issue.
完成的
添加一条评论
For me the solution was update the firmware and after the touchscreen start to work fine.
这个答案有帮助吗?
得分 0
1条评论:
I purchased one of these sapphire screens for series 3. Screen works but in constant restore loop. Firmware upgrade fails each time also
完成的
添加一条评论
添加你的答案
Blake Russell 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 70
总计 3,819
