跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
How do I set up iPhone if home button is broken?
I just repaired the screen on an iPhone 7. Bought it off ebay to repair, was listed as having cracked screen and home button not working. Received the phone and turned it on before repair, assistive touch was on but home button didnt work. Replaced the display, put everything back together, and powered back on. Now assistive touch button is gone, but still stuck at the screen with “press home to open.” How do I get past this without assistive touch, and why did it just go away, I didn’t reset or anything. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
  1. Connect your iPhone, to a computer with iTunes installed.
  2. In iTunes, select your device.
  3. From the Summary pane, click Configure Accessibility in the Options section at the bottom.
  4. Select the Voice Over and click OK.
  5. Double tap on the Press home to open text.
这个答案有帮助吗?
得分 0
3条评论:
thanks it worked
完成的
I am having the same issue. except my Mac doesn't have iTunes. I read that it's no more.
完成的
@caleag On newer versions of MacOS the iTunes functionality has been moved to the Finder. Just open up Finder and locate your phone on the left side of the screen and you'll be in business.
完成的
添加一条评论
Home bottom is broken then i cannot double tab on the home bottom
这个答案有帮助吗?
得分 0
添加一条评论
If your setting jt up for yourself, restart it.
这个答案有帮助吗?
得分 0
添加一条评论
if u need to get to the language menu turn on the phone then shut it off then u can turn it on and if will go to the sett up screen past the part where i need to press the home button
这个答案有帮助吗?
得分 0
添加一条评论
If I understand right, your iPhone is setup just missing home button on screen ? Swipe from right to left for camera, make any picture, then open picture in camera. In top right corner you will have ALL PHOTOS - tap on it - and you should be on screen to unlock you Phone with code. Unlock it and from bottom menu you should be able to get into Settings (depend how is your menu setup - I have it there).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Garrison Bates 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 29
过去 30 天: 108
总计 3,975
