跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
Boots from battery, but not from adapter
Replaced the DC-in board. As soon as I plug in the adapter, the menu bar says "Not charging". It is not an adapter problem - I use the same as the one for my same unit. Logic board?? That would be a shame, since everything else works.
Something did change when I replaced the DC-in: when I press the power button I hear some sort of sound for maybe 2 seconds, as if it were trying to boot, but the sound dies, and pressing the button again does not repeat the sound, until I unplug the adapter, re-plug it, the sound returns on the first press. So it looks like it is getting power from the new DC-in board?
Then I had this thought: Can I do some soldering and make the computer think the adapter is the battery?
Update (08/12/2011)
Don't know how I can add to my answer to my own post? When I submit without typing anything here, I'm told that this field is required and won't let me submit. When I submit with this field filled in, I'm told that I can't answer my own question??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try switching the DC-In board to the other machine to verify it.
这个答案有帮助吗?
得分 1
1条评论:
I can't, took the other unit apart. But I do hear a sound with the new DC-in / see my updated post. Any suggestions?
完成的
添加一条评论
添加你的答案
sieg deleu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 444
