跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Error in Diagnostics 4SNS/C0000008: TLOp--124
Hi
I have the above error in diagnostics. It appears to point to LCD Temperature Sensor. I have tested another LCD with my Mac and it isn't the LCD itself. This results in fans running at full speed as well as LCD Proximity reading as - in istat menu app.
Any help would be appreciated
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The error TLOp points to: ''Excessive LCD panel area temperature, Verify that the DisplayPort cable is securely connected to both the LCD panel and the logic board. This is straight out of the Apple manual.
I would say since you tried a second display and it too showed the error that points to the LVDS connector on the logic board its self the contact within it has a problem, the solder joint of the connector or the rest of the sensor logic within the logic board needs to be investigated.
这个答案有帮助吗?
得分 1
添加一条评论
I would first check that the the LCD thermal sensor cable connector is correctly in place. See step #8 of this guide:
iMac 因特尔 21.5" EMC 2428 显示屏更换
这个答案有帮助吗?
得分 1
1条评论:
The thermal sensor cable and connector looks fine. I've examined the pins inside the connector too and they look fine.
I do suspect the lvds connector now that Dan has mentioned it. There's a pin that looks slightly out but because it was working I didn't suspect it. But the more closely I examine it the more I think it is the LVDS connector on the logic board.
完成的
添加一条评论
添加你的答案
Faisal Gondal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 500
