跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
New Trackpad doesn't work
Hi, I bought a brand new trackpad from iFixit, installed it without too much trouble and sadly found out it barely registers any movement when I turn the machine on. It’s actually worse than the trackpad I replaced. I am trying to figure out if this is a bad part, or if there is something else that might be wrong. This computer works fine with pointing devices attached through bluetooth or USB. So, what do you think? Bad part, or something else wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did you replace the trackpad cable as well?
完成的
@danj - Yes, that is assuming it is the little flat cable that plugs into the back of the trackpad and then into the motherboard.
完成的
添加一条评论
1个答案
已选择的解决方案
Please check your battery for swelling.
这个答案有帮助吗?
得分 2
3条评论:
I replaced the battery as well, no swelling and the new battery seems to be functioning correctly...
完成的
Did you adjust the trackpad using the adjustment screw?
完成的
Yes. Tried it a number of ways. No luck. iFixit is sending a new trackpad... I'll give that a try.
完成的
添加一条评论
添加你的答案
Peter Frank 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 73
