New Trackpad doesn't work
Hi, I bought a brand new trackpad from iFixit, installed it without too much trouble and sadly found out it barely registers any movement when I turn the machine on. It’s actually worse than the trackpad I replaced. I am trying to figure out if this is a bad part, or if there is something else that might be wrong. This computer works fine with pointing devices attached through bluetooth or USB. So, what do you think? Bad part, or something else wrong?
2条评论
Did you replace the trackpad cable as well?
由 DanJ 完成的
@danj - Yes, that is assuming it is the little flat cable that plugs into the back of the trackpad and then into the motherboard.
由 Peter Frank 完成的
