跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Boot failure: phone quick-flashing on apple logo
Hello,
My sister’s iPhone seems to have developed a fault. It originally started with the phone randomly rebooting under battery power and then getting stuck on the apple logo. Once on the apple logo, it would continuously boot loop and not move past the apple logo. So it’d basically come on with the logo, wait a bit and then reboot.
If I plugged the phone into the mains, it would power up fine and then work. Taking out the charger would force it into a boot loop again (took some time for it to happen, time taken was random though - sometimes it’d do it instantly, other times not). Using PC to power the phone didn’t work. It had to be through the mains.
Now it seems the fault has developed one step further. Under battery power, it refuses to turn on. If I plug the phone into the mains, it will flash on the apple logo.
Here’s a clip of it in action: https://streamable.com/st8aa
Any idea what the problem is likely to be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Yup. It was the battery. Replaced it and the phone now works.
完成的
添加一条评论
1个答案
已选择的解决方案
The failure and behavior matches with that of a faulty battery, thus first step would be to check and probably replace it. You should get some indication of battery condition from battery settings inside the iPhone itself, or get more detailed info with 3Utools on a PC or Coconut battery on a Mac.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
hardstylez122 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 44
