跳转到主内容
The Samsung Galaxy Ace II X features a 1 GHz processor, a 5MP camera, and a 800x480 TFT screen.
13 个问题 查看全部
How to repair water damage phone?
Hi,
A friend gave is old phone because it not working. After dissembling it I can clearly see that it had been water damage because of the water indicator. It a Galaxy Ace II X. I tried cleaning it with dome alcohol and bought a new battery. After pressing on the power button a can only hear sone crackling coming from the earphone speaker. I tried plugging into a a computer it not detected. Do what should I tried now ?
Huge thanks for the help.
Update (12/22/2019)
Thanks for the answer,
I tried to totally submerge the motherboard in alcohol but it still not working. I search for anything that look bad but it doesn’t seem like there any corrosion on the electronic. I took a picture of it. Huge thanks for the help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
This is a hard question to respond, because many things can have liquid damage inside, but this is my personal rule:
“Inspect for liquid damage and corrosion, wherever is bad or looks bad needs to cleaned be replaced, if liquid touched the motherboard/circuit board, the same rule wherever is bad or looks bad needs to be cleaned or replaced.”
这个答案有帮助吗?
得分 0
添加一条评论
It looks very hard to fix it on your own. You may try sending it to a pro or a repair center if it is really important for you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jni Turbis 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 68
