跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 个问题 查看全部
Blown capacitor on logic board. What is it?
Long story short, my logic board went out. Started smelling like burnt electronics. Pulled the board out, and found one of the capacitors on the back side of the logic board was melted.
It seems like it would be fairly easy to replace, I just don’t know what capacitor it is, or where to find one. I know it looks like a D2E Case Tantalum capacitor, but beyond that, I’m not sure.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
The Cap is one of a group: C7370 which is a 68UF 20% 16V Poly-Tantalum in a D2E case
Here’s one source: Mouser
这个答案有帮助吗?
得分 1
5条评论:
Thanks a ton! I do have a follow-up question. (see second picture above) The blown capacitor is opposite the metal block (R36 446 RA7). I don't know exactly what that component is. Can't tell if they're connected or not.
Just wondering if there's anywhere I should check for a short or anything before replacing the capacitor?
Thanks again!
完成的
Also, the link seems to point to the wrong thing? It pulls up a 6.3V 220UF B case capacitor?
完成的
The R36 is an inductor coil Shielded Power Inductors
完成的
Thanks for the clarification!
完成的
添加一条评论
Found this question/answer that led me to the right replacement capacitor
Cannot find Tantalum - Polymer Capacitors that match
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brad P 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 27
总计 601
