Cannot find Tantalum - Polymer Capacitors that match
Hi, I need to replace CAP C7240 on a 820-3332 Macbook pro retina. the CAP is a 68uf 20% 16v poly-tant case-d2e-sm but cannot find them anywhere. I can only find the in a D2 size. Thanks!
Than you everyone for your help, I was able to replace it with mouser part number 80-T520D686M16ATE50 . Everything is back up and running.
这个答案有帮助吗?
carries a lot of the repair electronic components. Ask them.
这个答案有帮助吗?
If it fits and is rated at the minimum voltage and fardas then it may be compatible.
这个答案有帮助吗?
Im just worried about the physical size of it, im afraid the bottom shell would rub on it.
That may be an issue then
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 322
